discosimon Posted July 18, 2010 Share Posted July 18, 2010 hello if anyone can help me i have disco 2 td5 i've had a remap done as well egr bypass done for towing i've been loseing power i have looked a intercooler hoses and intercooler they seem ok i've been on a nanocon and autologic and all fine boost is ok changed my k&n filter as it was hissing put standard one in no hissing maf ok map sensor ok all small hoses to wastegate modulator fine and changed modulator to what next do not now........ Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 18, 2010 Share Posted July 18, 2010 Have you checked the fuel pressure? A failing pump can affect max power as the pressure drops as demand increases. It won't show as a fault and the ECU can't measure the rail pressure - you need to put some sort of gauge or sensor into the fuel line and cane it up a hill under full load to check it properly. Quote Link to comment Share on other sites More sharing options...
discosimon Posted July 22, 2010 Author Share Posted July 22, 2010 Have you checked the fuel pressure? A failing pump can affect max power as the pressure drops as demand increases. It won't show as a fault and the ECU can't measure the rail pressure - you need to put some sort of gauge or sensor into the fuel line and cane it up a hill under full load to check it properly. thanks i'll try it Quote Link to comment Share on other sites More sharing options...
