02jcole Posted July 20, 2010 Share Posted July 20, 2010 Hello, Does anyone know the part number for the lower swivel bolts on a 1997 defender 90. The knackered bolts I removed are M8 x 30mm hex head with a small section of unthreaded shaft. Thanks in advance, James Quote Link to comment Share on other sites More sharing options...
western Posted July 20, 2010 Share Posted July 20, 2010 (edited) item 14 on page 496 are the bolts for the lower swivel pins. please also refer to these 2 threads Links to Parts books,Microcat ,RAVE Info required for part numbers please specify Edited July 20, 2010 by western reference corrected Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 20, 2010 Share Posted July 20, 2010 Looks like BH108061M from the parts catalogue, but can't seem to find it other than below. http://www.classiclandrovers.no/?page=shop/flypage&product_id=24150&category_id=340&std_qty=4&PHPSESSID=a924e0305195908916ba8a0f5e53d22c LR series have verious M8 bolts but I think these might be 10.9 grade high tensile, so you might have to check that out. http://www.lrseries.com/shop/product/listing/6797/FS108307L-SCREW-M8-X-30-FLANGED-HEAD.html?search=M8 x 30&page=1 Mav Quote Link to comment Share on other sites More sharing options...
western Posted July 20, 2010 Share Posted July 20, 2010 the BH108061M is for pre-1997 vehicles with front disc & rear drum brakes. For vehicles with front & rear disc brakes use bolt FTC3455 these are what you need Quote Link to comment Share on other sites More sharing options...
02jcole Posted July 20, 2010 Author Share Posted July 20, 2010 the BH108061M is for pre-1997 vehicles with front disc & rear drum brakes. For vehicles with front & rear disc brakes use bolt FTC3455 these are what you need The bolts I removed were hex head, so there is no countersink in the lower swivel pin for ftc3455 bolts to fit? James Quote Link to comment Share on other sites More sharing options...
western Posted July 20, 2010 Share Posted July 20, 2010 then you need the earlier BH108061M bolts. which have been superseded by FS108307L Quote Link to comment Share on other sites More sharing options...
