Off Road Toad Posted July 20, 2010 Share Posted July 20, 2010 Have got an 'occasional' problem with my wifes disco. It's a 3ootdi R reg xs. Just occasionally and randomly the central locking doesn't respond. i then use the key to gain access. the alarm doesn't go off. I have full dash warning lights etc but on turning the key the starter won't turn. From what i've read i suspect the alarm spyder?. currently this happens maybe once per month and if i disconnect the battery for a couple of minutes it then all works fine again. Any ideas? Thanks, Steve Quote Link to comment Share on other sites More sharing options...
scube Posted July 20, 2010 Share Posted July 20, 2010 A friend of mine had a similar problem and was told it was the spider.. He kept plugging away to get to the bottom of the problem, even in desperation took it to a couple of garages. In the end it turned out to be the rear door curtsey light switch the wires behind the switch had chaffed. Worth checking the simple things first. Quote Link to comment Share on other sites More sharing options...
