Disco-Ron Posted July 20, 2010 Share Posted July 20, 2010 And........ can i simply get the stalk with that function and fit it on my 300 that doesn't have it...........?? Quote Link to comment Share on other sites More sharing options...
western Posted July 20, 2010 Share Posted July 20, 2010 all have a flick wipe facility, just flick the stalk down & release, later vehicles 300Tdi on certain models have a intermittent facility on the front wipers see below This is how I changed my 1989 110 to intermittent wash/wipe using genuine LR parts http://forums.lr4x4.com/index.php?showtopic=927 Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 20, 2010 Share Posted July 20, 2010 Both my 200's have intermittent in the down position, then off and then normal and fast continuous. To do a flick wipe I usually just push it up against the spring enough to trigger the wipe, but not enough to latch over onto normal speed. Tricky, but doable Alternatively just push it either up into normal or down into intermittent and then back to off again. The motor will finish the wipe as normal if your park switch is working properly. Quote Link to comment Share on other sites More sharing options...
Landy'd Gentry Posted July 20, 2010 Share Posted July 20, 2010 You could always fit a britpart wiper switch, then you'll have intermittant wipers, but not when you need them Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 20, 2010 Share Posted July 20, 2010 :hysterical: Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted July 21, 2010 Author Share Posted July 21, 2010 Mine has intermitent down, hence my question............ it does my head in, i'd rather have flick wipe and no intermittent.................. Quote Link to comment Share on other sites More sharing options...
western Posted July 21, 2010 Share Posted July 21, 2010 I can still get a flick wipe, just enough downward movement so the stalk doesn't latch, you can revert to the older system, but you;ll need the other stalk & disconnect the intermittent realy/wiring from the rest of the vehicle, bit of a retrograde step IMHO. Quote Link to comment Share on other sites More sharing options...
Gromit Posted July 22, 2010 Share Posted July 22, 2010 Mine has intermitent down, hence my question............ it does my head in, i'd rather have flick wipe and no intermittent.................. If the water tank is empty, the push-to-spray is essentially a flick wipe Quote Link to comment Share on other sites More sharing options...
Mike Jenkins Posted July 22, 2010 Share Posted July 22, 2010 My 1987 V8 SW has flick wipe and no intermittent. You push the stalk down for flick, and up once for slow continuous wipe, and up again for slightly faster. I recently replaced my stalk with a PRC3900 because the spring had gone, that was the right part for the flick wipe. Presume you have a relay/delay unit that you'll have to remove. Mike Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted July 23, 2010 Share Posted July 23, 2010 it's written in the manual, you push it upwards slightly just before it clicks into normal wipe to do a flick wipe. Serious. it's in the Td5 manual. Quote Link to comment Share on other sites More sharing options...
western Posted July 23, 2010 Share Posted July 23, 2010 but on a pre 200tdi vehicle the flick wipe function is a stalk down spring loaded return to off selection. Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted July 23, 2010 Share Posted July 23, 2010 so LR cheated us of this in lieu of a intermittent wipe. what is this.... how come they can't implement a pull and release to flick wipe. Quote Link to comment Share on other sites More sharing options...
western Posted July 23, 2010 Share Posted July 23, 2010 if you flick the stalk down but don't let it latch, it'll still do a flick wipe, at least mine does. Quote Link to comment Share on other sites More sharing options...
