Mack Posted July 21, 2010 Share Posted July 21, 2010 Hi all I had a look to the tech archive, but I´m not sure if it is necessary to replace the inner axle seals when greasing the wheel bearings. It is a Puma (same as Td5 setup, I believe). thanks M Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 21, 2010 Share Posted July 21, 2010 I assume you mean the inner hub seal? If you're re-greasing the bearings properly then the seal will have to come out anyway (to get the inner bearing out), so you may as well chuck a new one in for the cost of them. Quote Link to comment Share on other sites More sharing options...
Mack Posted July 21, 2010 Author Share Posted July 21, 2010 Right. I asked because I ordered a set of genuine seals, but I got "Britpart G", G standing for genuine Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 21, 2010 Share Posted July 21, 2010 They should be OEM ones, all the Britpart stuff I've had in the past with a 'G' has been OEM. However if you ordered 'Genuine' then send them back. Genuine should come in a LR bag/box. You've got OEM, which is NOT the same (even though the actual item may well be). Quote Link to comment Share on other sites More sharing options...
