ajh Posted September 18, 2017 Share Posted September 18, 2017 No kidding, it has me thinking that I should just put the blown 300 into the challenge truck and buy a used TD6 for the Tomcat. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 18, 2017 Share Posted September 18, 2017 The MT82 6th is actually 0.742:1 (not 0.79). Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 18, 2017 Share Posted September 18, 2017 And the PUMAs have the 1.2 transfer case as well, so it is a much higher top gear (20%) than the previous models. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 19, 2017 Share Posted September 19, 2017 Similar gearing to LT77/R380 5th + 1.4 LT230 + Overdrive then. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 19, 2017 Share Posted September 19, 2017 For top gear, yes. 1st on the 6 speed is still much lower. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted September 19, 2017 Share Posted September 19, 2017 Don't forget the common issue with the 6 speed as fitted to the TDCI's is their unfortunate habit of sometimes leaving you with no drive due to sudden failure of the intermediate shaft between the main and transfer boxes. This is a reasonably common issue that is due to lack of lubrication of the fine splines during initial transmission assembly at the factory. That said having owned Puma's I never personally suffered failure but that really was down to luck and maybe knowing the issue it was me being gentle with both feet. First gear is low and good for starting off when towing but for on the flat road starts on a flat road without a trailer I'd generally use second. Quote Link to comment Share on other sites More sharing options...
ajh Posted September 19, 2017 Share Posted September 19, 2017 In my case I'm looking at TD6/TDV6 applications, so the ratios make a lot of sense and having something that can be fitted with a short shifter is attractive in a racer. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 19, 2017 Share Posted September 19, 2017 3 hours ago, Happyoldgit said: Don't forget the common issue with the 6 speed as fitted to the TDCI's is their unfortunate habit of sometimes leaving you with no drive due to sudden failure of the intermediate shaft between the main and transfer boxes. This is a reasonably common issue that is due to lack of lubrication of the fine splines during initial transmission assembly at the factory. That said having owned Puma's I never personally suffered failure but that really was down to luck and maybe knowing the issue it was me being gentle with both feet. First gear is low and good for starting off when towing but for on the flat road starts on a flat road without a trailer I'd generally use second. Ashcroft does a fix. http://www.ashcroft-transmissions.co.uk/mt82-output-shaft-kit.html Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted September 19, 2017 Share Posted September 19, 2017 34 minutes ago, Red90 said: Ashcroft does a fix. http://www.ashcroft-transmissions.co.uk/mt82-output-shaft-kit.html Yep, and others have fitted grease nipples to the shaft joint and cut access holes in the shaft housing too. Thing is it's a known issue since the introduction of the 6 speed but one that LR have never recognised but will usually fix if the vehicle is still under warranty. That's little comfort of you suddenly loose drive though. It's luck of the draw as some shafts go on while others give up the ghost, obviously the transfer box needs to come off to get to it. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 20, 2017 Share Posted September 20, 2017 15 hours ago, ajh said: In my case I'm looking at TD6/TDV6 applications, so the ratios make a lot of sense and having something that can be fitted with a short shifter is attractive in a racer. Isn't that a completely different gearbox to the TDCi then? Quote Link to comment Share on other sites More sharing options...
dave88sw Posted September 20, 2017 Share Posted September 20, 2017 On 9/19/2017 at 7:29 PM, ajh said: In my case I'm looking at TD6/TDV6 applications, so the ratios make a lot of sense and having something that can be fitted with a short shifter is attractive in a racer. As fridgefreezer says, the tdci box probably isn't the best suited. if you're going TDV6, why not look at the 6 speed Disco 3/4 manual box that will bolt straight up to the engine. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted October 10, 2017 Share Posted October 10, 2017 How about an allison auto like I have in my RV First Second Third Fourth Fifth Sixth Reverse 3.49 : 1 1.86 : 1 1.41 : 1 1.00 : 1 0.75 : 1 0.65 : 1 -5.03 : Quote Link to comment Share on other sites More sharing options...
