Soylent Green Posted July 21, 2010 Share Posted July 21, 2010 Hi everyone! Can anyone help me with a small problem? (no not that one!) since i got my Defender td5 110 the inside light fails to come on when the doors are opened! now if i open them without killing the alarm the alarm goes off, telling me that the door switch/s are working? if i switch off the alarm via key-fob the inside light comes on for just a split second?then off again! i have checked the switch on/off everything works! a fellow landy owner told me that the settings in the ECU may have been reset i.e. the length of time the inside light stays on for? 1. Is this possible? 2. Could it be something else other than ECU? 3. when will the pain stop? Thanks for any in put! Quote Link to comment Share on other sites More sharing options...
crwoody Posted July 22, 2010 Share Posted July 22, 2010 1. The interior lights are switched from the alarm ecu, they need to be set/activated using a plug-in diagnostic utility, Nanocom for example. 2. Doubtful. 3. Never, there will always be something else, it's a Land Rover thing. Quote Link to comment Share on other sites More sharing options...
Soylent Green Posted July 23, 2010 Author Share Posted July 23, 2010 1. The interior lights are switched from the alarm ecu, they need to be set/activated using a plug-in diagnostic utility, Nanocom for example. 2. Doubtful. 3. Never, there will always be something else, it's a Land Rover thing. Thanks crwoody! i remember reading in the service record someone had been into the ECU and reset codes and faults? MMmmm i guess i will just have to live with it till i find a Nanocom by the roadside Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted July 24, 2010 Share Posted July 24, 2010 I had a weired problem wiht my 110, its ex MOD Plod so has seen a few door opens an slams.. The driver door plunger was disconnected, when I reconnected it the alarm kept going off, so I got a new one and its been fine ever since, light comes on and off as it should do... Quote Link to comment Share on other sites More sharing options...
