henk Posted July 22, 2010 Share Posted July 22, 2010 Is there a huge difference between the exhaust and the exhaust manifold of a 2.5d and a 2.25d? I have a 2.5d in my 88 but used the exhaust nd the manifold of the 2.25d Quote Link to comment Share on other sites More sharing options...
Outrage Posted July 22, 2010 Share Posted July 22, 2010 The 2.5 manifold is larger diameter I think, to match the larger diameter exhaust off a 90/110. The manifold studs will not mate with the flange of a standard series 3 exhaust. I used the 2.25 manifold to match to 2.25 exhaust on mine. I've noticed no power problems although others have suggested it will reduce the power output substantially. Cheers, Lee Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted July 22, 2010 Share Posted July 22, 2010 Its just the flange dimensions that differ. The comments about power loss are due to the 2.25 exhaust pipe being a smaller diameter than the 2.5 pipe. Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 23, 2010 Share Posted July 23, 2010 I found that my 2.5 nad had temperature problems uphill despite a brand new cooling system with a 2.25 exhaust, even after a full rebuild with rebore, pistons, crank grind and new valves. Fitting a 2" exhaust cured the problem immediately. Though the overheating never enetered the red one, years of elevated temperatures led to cracked pistons, so don't be tempted to use a 2.25 exhaust on the 2.5 engine. Quote Link to comment Share on other sites More sharing options...
