Paddy_SP Posted July 24, 2010 Share Posted July 24, 2010 I'm in the process of adjusting my 300TDi's fuelling - as a result I've just removed the throttle position sensor in order to remove the cover plate. Am I right in thinking this is part of the EGR's control system, and that as it has been blanked off, I can simply unplug and remove the sensor? As ever, any help would be most appreciated! Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted July 24, 2010 Share Posted July 24, 2010 Yes, the fuelling's all mechanical, the sensor just tells the EGR to open at medium revs and part load. Quote Link to comment Share on other sites More sharing options...
white90 Posted July 24, 2010 Share Posted July 24, 2010 throw it away needless junk. Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted July 24, 2010 Author Share Posted July 24, 2010 Many thanks chaps - I do like removing any unnecessary stuff! Quote Link to comment Share on other sites More sharing options...
white90 Posted July 24, 2010 Share Posted July 24, 2010 there is also a solenoid/wiring and vacum tube on the bulkhead when removing this you need to seal the pipe from the airbox to the Turbo remove the EGR as well replace the top pipe with a straight Rubber one from a Non EGR car Quote Link to comment Share on other sites More sharing options...
