reb78 Posted July 24, 2010 Share Posted July 24, 2010 My lift pump died properly this morning, on my 200tdi defender engine, leaking diesel out under the vehicle. I'm nowhere near my spare one and have 100 miles to drive to get home,so had to go to the dealer who originally wanted £130 for the part! I mananged to get a slight discount, but had no choice but to buy it. Anyway, the part came with a 1/4inch spacer for where it bolts onto the block. The old pump didnt have a spacer and neither did the one before that. Thats not to say they didnt need one though! When do we need to use the spacers on these pumps. My block has a cast peice where the pump attaches the same shape as the spacer, so i presume i dont need to use it, however, on fitting the pump, even with the cam lobe away from the lever, it still sits up on it slightly without the spacer - is this correct? I think the spacer in my case would mean that the lever would not touch the cam lobe in this position. The other thing the dealer failed to supply for that price was a single gasket to use if the spacer is not required, so i have used hylomar liquid gasket - hope that will be ok? Lastly, what are the chances of diesel having got into the sump with this failure? Should i change the oil? Thanks! Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2010 Share Posted July 24, 2010 spacer not required if [as yours has] the raised builtin section, same lift pump is used on the old TD engine & that needs the spacer. IIRC there's a drain hole in bottom of LP to let any stray fuel out, so it shouldn't hopefully get in the sump. Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 24, 2010 Author Share Posted July 24, 2010 Thanks Ralph. Thats what i thought - its running ok. The diesel was pouring out of the drain hole and leaving a puddle underneath. Dont think the oil level has gone up, so reckon thats all ok. Will check it in a couple of days to check the hylomar has held up in the absence of a gasket! Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2010 Share Posted July 24, 2010 if you want a gasket drop me a pm or e,mail with your address, I've got a few spare. Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted July 25, 2010 Share Posted July 25, 2010 I've never been able to find the part number of the spacer in my parts book-I need one for a lift pump I mistakenly bought for my 2.5NA which dosnt have one. Quote Link to comment Share on other sites More sharing options...
western Posted July 25, 2010 Share Posted July 25, 2010 You won't find a part number for the spacer, it's a NSS = Not Sold Seperatly only comes with a new lift pump. Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 25, 2010 Author Share Posted July 25, 2010 Cheers Ralph, I'll PM you my address. Rusty Nissan - you can have my spacer - i dont need it! Quote Link to comment Share on other sites More sharing options...
western Posted July 25, 2010 Share Posted July 25, 2010 Ok, I'll get one ready to post. or shall I scan it & post it here then you can download it & cut it out & fit it Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 25, 2010 Author Share Posted July 25, 2010 Ok, I'll get one ready to post. or shall I scan it & post it here then you can download it & cut it out & fit it PM sent. Quote Link to comment Share on other sites More sharing options...
western Posted July 25, 2010 Share Posted July 25, 2010 PM sent. got it & ready for posting. Quote Link to comment Share on other sites More sharing options...
