Marco Posted July 26, 2010 Share Posted July 26, 2010 My Paddocks vented and drilled ones (solid to VIN KA) are now warped... only fitted them last year so looking for a better lasting alternative. Paddocks is listing both Mintex and AP Lockheed solid ones @ 15,95 ex VAT... any feedback on the brands / discs? Cheers Marco Quote Link to comment Share on other sites More sharing options...
western Posted July 26, 2010 Share Posted July 26, 2010 Mintex & AP Lockheed are very wel known & the companies have been around for over 20years, so either would be a good buy. Quote Link to comment Share on other sites More sharing options...
Marco Posted July 26, 2010 Author Share Posted July 26, 2010 Mintex & AP Lockheed are very wel known & the companies have been around for over 20years, so either would be a good buy. Thanks, I actually did guess the same but also wonder if there should be any differences between the two brands/discs. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 26, 2010 Share Posted July 26, 2010 I've used Mintex brake stuff for all mine and they always seem fine. If your vehicle has vented disc type calipers you'll need to use vented discs, but I would reccomend just 'normal' vented ones, not cross-drilled/grooved fancy things. Otherwise, all 90/110 front solid discs are the same (post 1990/1991 ish.) Part no FRC7329. Quote Link to comment Share on other sites More sharing options...
Marco Posted July 26, 2010 Author Share Posted July 26, 2010 I've used Mintex brake stuff for all mine and they always seem fine. If your vehicle has vented disc type calipers you'll need to use vented discs, but I would reccomend just 'normal' vented ones, not cross-drilled/grooved fancy things. Otherwise, all 90/110 front solid discs are the same (post 1990/1991 ish.) Part no FRC7329. I did "upgrade" to the Paddock drilled ones but will refit standard solid one and use the 'fancy' ones as flower pots?? Suggestions for re-use welcome (haha) Quote Link to comment Share on other sites More sharing options...
Prith Posted July 26, 2010 Share Posted July 26, 2010 Is it possible to swap sold disc to vented cross drilled discs on my 1990 110? Does anything else need to be changed? Quote Link to comment Share on other sites More sharing options...
markyboy Posted July 26, 2010 Share Posted July 26, 2010 Is it possible to swap sold disc to vented cross drilled discs on my 1990 110? Does anything else need to be changed? Yes, the calipers would need to be changed as the vented discs are thicker. Mark. Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 29, 2010 Share Posted July 29, 2010 AP Lockheed are OEM. Your warped discs are probably Britpart, which have a reputation for warping and, of course, are Paddock's primary supplier. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 29, 2010 Share Posted July 29, 2010 Buy nothing in a white box that noboy owns up to making, and same to Britpart even though they do Mintex AP Brembo Delphi Nige Quote Link to comment Share on other sites More sharing options...
Marco Posted July 29, 2010 Author Share Posted July 29, 2010 AP Lockheed are OEM. Your warped discs are probably Britpart, which have a reputation for warping and, of course, are Paddock's primary supplier. Thanks, in the meantime I did buy the Mintex ones... arrived today. I might get another set, maybe AP as I do have the same vented 'performance' BP parts at the back. Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 30, 2010 Share Posted July 30, 2010 AP Lockheed are OEM. Your warped discs are probably Britpart, which have a reputation for warping and, of course, are Paddock's primary supplier. Jeez, you could have said a little sooner, I just recived some BP solid discs yesterday... I didn't think I could go wrong with discs, as long as they fit there's not a lot more you can get wrong with them! So you're saying they're like the chocolate money you get in xmas stocking, or an Amadillo... crutchy on the ouside, soft on the inside..... Quote Link to comment Share on other sites More sharing options...
Quagmire Posted July 30, 2010 Share Posted July 30, 2010 I have had solid Britpart discs on my 90 for the last 2 years (front) and 6 months (rear) and they are fine- however I don't have Britpart pads! Didn't know they had a reputation of warping though? Mine have been through some pretty hard stops with no probs, and done a bit of towing here and there too - all totally fine. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 30, 2010 Share Posted July 30, 2010 Considering a proper Mintex or Lockheed disc only costs a fiver more than a Britpart disc from Paddocks, I think there's no excuse Wouldn't change them for the sake of it though, only if they develop problems Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 30, 2010 Share Posted July 30, 2010 Ferodo also make good discs for Land Rovers Mo Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 30, 2010 Share Posted July 30, 2010 Considering a proper Mintex or Lockheed disc only costs a fiver more than a Britpart disc from Paddocks, I think there's no excuse Wouldn't change them for the sake of it though, only if they develop problems Exactly. If your BP ones are OK, then there's no reason to change them. But I'd recommend Lockheed or EBC next time for peace of mind and known reliability. To be fair, I'm highly sceptical about Britpart and have been one of their loudest critics, but they are supposed to be trying to improve their quality across the board, being well aware of the level of criticism they get on forums like this. Some of their bad lines have reportedly already been improved, and brake discs may be one of them. Let's hope they do turn it around. Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 30, 2010 Share Posted July 30, 2010 but they are supposed to be trying to improve their quality across the board, being well aware of the level of criticism they get on forums like this. Some of their bad lines have reportedly already been improved, and brake discs may be one of them. Let's hope they do turn it around. Who'd you hear this from? I've written them a letter and heard nothing from them?? unfortunatly to me that does not fill me with any kind of confidance of them improving there quality? as an engineer by proffesion, it drives me up the wall the lunacy of the General managment and managment of the QA of that company. Appologies for the rant. Quote Link to comment Share on other sites More sharing options...
Dan Posted July 30, 2010 Share Posted July 30, 2010 Hi All, I have been having problems with squealing brakes. I have Britpart discs and lockheed pads. I have tried various pads (lockheed and ebc) and it did not improve. I have also tried lots of the normal tricks. Now I am not saying it is the britpart discs, but before I fitted them I had no issues. I am hoping this weekend to get some mintex pads and discs fitted. I hope these will improve the situation. If it does after a few weeks. I will probably be putting it down to the britpart discs. In which case I will then be deciding if I want to follow up with Britpart. So i'll let you know. Dan Quote Link to comment Share on other sites More sharing options...
Martin Cooper Posted September 13, 2017 Share Posted September 13, 2017 (edited) It is HIGHLY unlikely the discs are warped. This is one of those myths. The only thing warped will be the diagnosis. Like the one about that big-bore exhaust, "It gives more power, see?" and stickers to make cars go faster. Sometimes discs crack. Drilled discs on a Land rover? Don't make me laugh. See them, and mark the IQ of the owner accordingly. Edited September 13, 2017 by Martin Cooper Quote Link to comment Share on other sites More sharing options...
