dcdefender Posted July 28, 2010 Share Posted July 28, 2010 Recently fitted a new fuel lift pump to my Defender 200tdi. Noticed slight dripping on top of oil filter. So re fitted with gasket sealant to make sure it was sealed properly. Still have a slow drip from underside of pump from the pump arm? Can I repair this or is it time for another new pump from Paddocks!? I have only been using this pump for two months1 Is it a case of unlucky fault or Britpart inferior quality? Any help appreciated TA DC Quote Link to comment Share on other sites More sharing options...
jbs Posted July 28, 2010 Share Posted July 28, 2010 Buy a different make of lift pump-Britpart have a really bad reputation in the standard of manufactured stuff they sell I've used in the past an allmakes lift pump and had no problems at all using one of them HTH John Quote Link to comment Share on other sites More sharing options...
western Posted July 28, 2010 Share Posted July 28, 2010 where is it dripping from ? there's a drain hole on the underside of lift pump if not dripping from there, recheck the pipe connections are tight. Quote Link to comment Share on other sites More sharing options...
dcdefender Posted July 28, 2010 Author Share Posted July 28, 2010 Buy a different make of lift pump-Britpart have a really bad reputation in the standard of manufactured stuff they sell I've used in the past an allmakes lift pump and had no problems at all using one of them HTH John thanks John I think you are right. Quote Link to comment Share on other sites More sharing options...
dcdefender Posted July 28, 2010 Author Share Posted July 28, 2010 where is it dripping from ? there's a drain hole on the underside of lift pump if not dripping from there, recheck the pipe connections are tight. Drip seems to be directly centre and underside of pump lever. Quote Link to comment Share on other sites More sharing options...
western Posted July 28, 2010 Share Posted July 28, 2010 sounds like the diaphragm is leaking or a internal seal, needs replacing, get a Delphi unit if you can. Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 28, 2010 Share Posted July 28, 2010 Sounds like what happened to me at the weekend - ended up getting worse, running very poorly and leaving a diesel puddle so had to be replaced asap. My old unit was a delphi one - was fine but only lasted 2 years (i expected a little more) but they should be good units - OEM i think. My new one should be made of gold for the price i paid for it from the STEALER! (it was an emergency of sorts as i was away from home). Also expected a full set of gaskets for the price i paid but thankfully a kind soul stepped in and sent me one ! Quote Link to comment Share on other sites More sharing options...
dcdefender Posted July 29, 2010 Author Share Posted July 29, 2010 Thanks for advise- Where the best place to buy a Delphi? TA DC Quote Link to comment Share on other sites More sharing options...
dcdefender Posted July 29, 2010 Author Share Posted July 29, 2010 Purchased a delphi fuel lift pump from landrox 4x4 £21.00 inc vat Also bought new nuts and olives to ensure job is done right. Thanks for advice. DC Quote Link to comment Share on other sites More sharing options...
