could someone with EPC please check something for me???
need to put in an order to one of the 'addocks...
i'm after some ball joints for the trackrod (behind axle) for my 1996 disco.
both ends are the same, as it has an adjuster in the rod.
i think i need RTC5869 Ball joint RH. but don't want to order the wrong one as i have 6 'left handed' ones in the workshop!! :rolleyes:
cheers
m@tt. :)
Yep, you think correct :D
FOR FUTURE REF.
RTC5869 =RH
RTC5870 = LH
problem is which way round is it fitted.
the RH/LH refers to the thread not the end of the trackrod as the trackrod itself can be fitted either way round.
once the ball joint ends are fitted, doesn't matter which way round, but it would be preferable to have the RH thread on the vehilces RH side, just to make it easy to remember.
