After much googling over which PAS pump is suited to which application, my confusion is only deepening, so as a forum can we put our heads together to get down in one thread which model each of the below is for, the type of fittings and the variations between the models etc.
NTC8287, According to google this has a banjo fitting on rear, and a stub pipe on the top casing. Is this for 300tdi only?
NTC8288, Appears to have a stub pipe on the top casing and a compression fitting on the side of t
