SCADA Posted July 31, 2010 Share Posted July 31, 2010 Hi, Every now and again my TD5 gives off three warning chimes when she is started up and I cant fathom what it is, owners manual suggests ABS however no other warnings are visible on the dash board. Only tell tale I have is that sometimes when accelarating the revs stay high whilst changing gear, as in there dont fall off when I take my foot of the gas. Thanks in advance. BK. Quote Link to comment Share on other sites More sharing options...
oldsscool Posted July 31, 2010 Share Posted July 31, 2010 mine does the same - just every so often - my mates had 2 td5s also and he said both his did it every so often Quote Link to comment Share on other sites More sharing options...
JourneyMan Posted July 31, 2010 Share Posted July 31, 2010 As oldsscool says, the chimes are normal, mine does the exactly the same, totally random but from what two different dealers have told me, its more noticeable on post 2003. As for the change point on the Auto, ditto I'm afraid, mine seems to have a mind of its own, sometimes it'll change at 2000 rpm sometimes at 3000 rpm regardless of pedal pressure, accompanied by a booming as the revs build, but they all seem to do this. Cheers Quote Link to comment Share on other sites More sharing options...
mayur Posted August 1, 2010 Share Posted August 1, 2010 have you checked that your transmission fuild to make sure it is at the right level ? this should normaily be done first thing in the morning or when the engine is compleatly cold Quote Link to comment Share on other sites More sharing options...
SCADA Posted August 1, 2010 Author Share Posted August 1, 2010 I should have pointed out that my Disco is a manual box. Quote Link to comment Share on other sites More sharing options...
