benbenukuk Posted August 1, 2010 Share Posted August 1, 2010 Hello, I have no working indicators on the rear of my 90 but the front ones work fine, If I put the lights on then try the passenger side indicator the number plate flashes, Any ideas? cheers. Ben Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 1, 2010 Share Posted August 1, 2010 Hello, I have no working indicators on the rear of my 90 but the front ones work fine, If I put the lights on then try the passenger side indicator the number plate flashes, Any ideas? cheers. Ben The wiring is goosed and you have a bad earth. Remove the covers in the back left and back right corners of the rear tub and investigate the rot / damage / corrosion. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted August 1, 2010 Share Posted August 1, 2010 Yup, I agree, one circuit affecting another is a classic indication (pun intended) of an earthing (or lack of) problem. Quote Link to comment Share on other sites More sharing options...
