The V8 Porn Rebuild Thread
Right
The build commences.
Starting with the relinered block, which has been in a cleaning tank x 2 times
So, 1st thing to do was to clean it - seriously clean it
Cleaning tanks despite what people think are not enough, you have to be sure in getting every
last piece of dirt outm, every last bit of swarf, if you don't it will find its way out
at some future pint - cleanlyness is everything
So, with a suitable sort of stand, a Steam cleaner, Engine degreaser, Jizer, pipe cleaners
and a couple of scrubbing brushes and toothbrushes it go hit big time.
I DELIBERATELY did about 30 mins on it, and then removed the 2 bungs screwed in at the back of the
oil ways - se one dribbled as soon as removed old oil, thats 2 x tank cleans and 1 x 30 mins steam scrub and
cleaners...
These and others were then reblasted squirted and cleaned then the whole load air lined dry and sprayed with oil to
ensure nothing goes rusty pre the build up
post-22-070609900 1283877284_thumb.jpg post-22-037697100 1283877298_thumb.jpg
Which is coming soon, very soon, few more bits to clean :)
Nige
Was taking shape,
but whilst working on the head rebuilds the inlets valve guides are betwwen gastly and
absolutely horrendous the valves flopped about like a floppy thing in a bucket of slop :(
New Bronze guides ordered from JED... and a bill to come from him ...and an Engineering company
who thought they were only going getting enough £s to polish the crank :(
Bugger sums it up
Nige
Just seems everything I touch has a "Problem"
Was hoping to have the bottom end back together this week, call from the machine shop was that whilst
the main and big ends only needed a polish, the crank seal journal was badly scored and needs machining
down and resleeving, so will be another 10 days
The heads that needed 8 inlet guides, now cleaned now really needs 8 exhaust guides, these will be with me next week,
so can get to him the week after, and then heads remachined back to me week after that
The timing chain dmaged, so needs new kit, sump has a HUGE flattened area where clouted, and stariner bent,
which cracked when tried to straighten, sump is a "Eales Special" so have another std sump, just need to chop
out all the baffles, then weld in the baffles I removed from the Eales sump
and so it goes on, I have a larger selection of cleaned parts and a smaller wallet, but nothing even looking like an engine :(
Hey Ho
And the next prob is ? :angry:
:lol:
Nige
Just think of the end result and all the associated benefits and it will all be worth it....
A tank currently takes you 120 miles or so.... You will be able to take more breaks when that falls under 100 per tank...
That should be in tune with your need to rest and have a snooze.. .(I hear it becomes more frequent when you are old..... )
Neil
