calle-fas Posted August 10, 2010 Share Posted August 10, 2010 Hi. I read a post a while back about there being different output splines for LT230 PTOs. Have searched but can't find it. Please point me in the right direction and delete this thread if you can. Now to the question. I've just received a PTO unit for my LT230 suffix unknown. The car is a Td5 110 -00 (SALLDHM88YA184884) if that helps. On the picture below i have the right hand shaft, with fewer teeth. Question is, will this be able to run my hydraulic pump, or is it just a dummy that needs to be replaced before any serious use? The pump is a Sunfab 24ccm. If I've read the power diagram right it will consume somewhere around 20kW at max. This is also what the PTO unit is specified for. Primary use will be competition winching. Quote Link to comment Share on other sites More sharing options...
Ruuman Posted August 11, 2010 Share Posted August 11, 2010 To my knowledge it should be fine. I recently had a friends hydro pto apart and it had the standard output as pictured on the right. I was also planning to use the standard gear on my setup. Not seen the left hand side output before. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted August 11, 2010 Share Posted August 11, 2010 One on the left looks rather heavier duty, although it also looks like the mainshaft end was pretty poorly lubricated. Is it me or does the helix angle on the ouside look different too? Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted August 11, 2010 Share Posted August 11, 2010 Is the LH one in the photo a very early one i.e. pre disco era. Quote Link to comment Share on other sites More sharing options...
calle-fas Posted August 11, 2010 Author Share Posted August 11, 2010 Thanks all. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 12, 2010 Share Posted August 12, 2010 Is the LH one in the photo a very early one i.e. pre disco era. Our survey says... Yes! The one on the right is the earlier LT230R type, non-interchangeable for obvious reasons. Quote Link to comment Share on other sites More sharing options...
zoltan Posted August 5, 2011 Share Posted August 5, 2011 Googling around to find information on the actual LT230 PTO spline with no success I found this thread, does anyone know the spline used for the PTO on the LT230? Quote Link to comment Share on other sites More sharing options...
nikojo Posted August 11, 2011 Share Posted August 11, 2011 The one with "fewer teeth" is the CORRECT one............it is the "Q" spec with "dog clutch"...............it also has cross drilled shaft. Quote Link to comment Share on other sites More sharing options...
Daan Posted August 11, 2011 Share Posted August 11, 2011 Does the one with more teeth line up with the one with less teeth? I think they are the same spline, but the one with fewer teeth just has every other tooth left out. I have the one on the right with fewer teeth to drive my PTO. daan Quote Link to comment Share on other sites More sharing options...
nikojo Posted August 14, 2011 Share Posted August 14, 2011 Don't know. Obviously depends on the adapter plate. Can't find a picture of it to see. Quote Link to comment Share on other sites More sharing options...
Mr Ian Posted August 14, 2011 Share Posted August 14, 2011 Hi Daan you are right , the spaces between teeth ,ie missing teeth, allow easier faster engagement of the drive dog, same spline profile. Same concept as the Series front drive. Regards Ian Ashcroft Quote Link to comment Share on other sites More sharing options...
