Top Tip
white90
When using a 9.5mm drill bit to lock the fuel pump, If the bit is slightly stuck an you reach for a set of pliers to help its removal, Be very mindful that when it comes out with a little more vigour than usual the next stop for the said drill bit is the Radiator, I wasn't and punctured a 6month old Rad DOH!
Luckily I've managed to have it repaired and all is wll again.. :D
An additional 'pearl of experience':
Also check that the drill-bit has gone far enough into the hole to enter the fuel pump. I just stopped when it dropped into the first hole it came to (which wasn't the timing hole) :-(
Consequently, my timing was WAY out and I had to start it all again - D'OH!
Dunk
Oops !
Perhaps the tech section should be renamed "Tony's Top Tops", it has a nice alliterative feel don't you think ? :)
Mo :)
For the record, a 9.5mm drill bit should not be tight in the hole. It just appears tight as the pulley is trying to turn against it. Wiggling the pulley too and fro (a SMALL amount) with a spanner on the nut should allow the drill bit to slide out without a fight. Make sure that the flywheel timing pin is out first though! :)
Bad luck Tony, glad you managed to repair the rad. :) Were you doing the whole job or just the timing?
Chris
