tweetyduck Posted August 15, 2010 Share Posted August 15, 2010 Help. i'm in the process of chaging the spill return fuel pipe. Easy job i thought. 15 min job. Not so. I've got a new return pipe (page 237 Parts book) the end right at the bottom has a banjo and bent soild pipe. picture here. where the shiny new pipe connects to the plastic fuel pipe theres a connector that requires a new olive. Rather like the ones you use in plumbing but smaller. Where can i get one today? any ideas ? Not really a parts request but if you know the part number it would help. I more need to know if i can get one from B&Q and what size it is. Would a motor factors sell them and what do i ask for ? Could it be a page 542 NRC9771 8mm olive ? would they sell them at a plumbers ? Quote Link to comment Share on other sites More sharing options...
western Posted August 15, 2010 Share Posted August 15, 2010 borrowed from Brookwells website -- refer to the note Injector Spill Rail 300TDI Ref: MJN100910 Product Description: This injector spill rail fits Defender models with 300TDI engines . NOTE: May need 1x NRC9970 Nut & NRC9771 Olive. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted August 15, 2010 Author Share Posted August 15, 2010 Thanks. So it looks like they are 8mm. B&Q do sell 8mm. Great. The nut is fine. I'll cut it off the one i'm taking off. Quote Link to comment Share on other sites More sharing options...
western Posted August 15, 2010 Share Posted August 15, 2010 It should be possible to recover the exising nipple, check the external diameter & the depth of the B&q item is the same otherwise you won't get a good leak free joint. personally I'd go for the genuine item. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted August 15, 2010 Author Share Posted August 15, 2010 decided to use half the old part and replaced the entire flexible part from the new one (the flexy parts were almost knackered). I'll order some olives to make the old part a spare for the trip and get some spare fuel hose. Any idea where i can get the braided fabric covered hose used on the spills? Quote Link to comment Share on other sites More sharing options...
western Posted August 15, 2010 Share Posted August 15, 2010 wouldn't worry about it being fabric covered like the original, any decent car spares shop should have a suitable size fuel/diesel resitant hose to use. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted August 15, 2010 Author Share Posted August 15, 2010 thanks. wish i'd just got some hose now and not bothered with a new spill. oh well it was cheaper than the one in your link,,,live and learn. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 15, 2010 Share Posted August 15, 2010 thanks. wish i'd just got some hose now and not bothered with a new spill. oh well it was cheaper than the one in your link,,,live and learn. Could have sworn I recommended just that in your other thread As Ralph says, any motor factors should be able to match you up some hose. 1/8" ID (3.2mm) on my 200Tdi. Can be had on eBay too. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted August 15, 2010 Author Share Posted August 15, 2010 Yes i see what you meant now. I did take note and it was only after looking back that i thought i'd give it a try based on your advice. I'd already ordered the part and didn't think they would just pull off !!! Who'd have thought pulling off would be so easy....LMAO. Thanks both for the advice. Its done..Water Pump and P Gasket also done. Not a bad day all told. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted August 15, 2010 Share Posted August 15, 2010 I'd recommednd a bit of heatshrink sleeve over the ends of the braided pipe to make it secure and stop it fraying - I used 7mm from Maplin and warmed it a bit with a warm air gun, but as the engine has got warmer it seems to have shrunk it on a little more. Nigel Quote Link to comment Share on other sites More sharing options...
jbs Posted August 15, 2010 Share Posted August 15, 2010 Neill, Since when anything job wise on a land rover take 15 minutes? John Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted August 15, 2010 Author Share Posted August 15, 2010 @crackshifter thats a damn good idea. Already have loads of heat shrink. I will do that tomorrow when i do the timing belt Thanks @jbs 15mins....the wife would be so lucky. Quote Link to comment Share on other sites More sharing options...
