moose Posted August 16, 2010 Share Posted August 16, 2010 morning all, All the disco's i have had the window switches all ways seen to work differently to how you would think they would. ie you press the top of the rocker button to lower and not the bottom. with my current truck (96 300tdi poverty spec) the rear windows haven't work since i obtained it, so I replaced the window ecu due to the dry joint solder problem. Now the rear windows work but the button operation is different to the front windows (ie you press the bottom of the rocker to lower the window). The switches are keyed with the plug so it not like i have put the plug on upside down. SO is it normal for the front window switches to operate in a different direction to the rear? guess quickest solution this would be just turn the switch upside down Quote Link to comment Share on other sites More sharing options...
Paul 200 TDI Posted August 16, 2010 Share Posted August 16, 2010 Yep, turn the complete switch over. There should be 2 different kinds of arrows for up and down, check to see if the doors ones are the same as the console ones Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted August 16, 2010 Share Posted August 16, 2010 If it helps my Td5 is the 'correct' way round - i.e. press the bottom of the switch to lower. Plus the front and rear switches are in the alternative places, i.e. the front windows are the lower switches. Just turn and move the switches around until you're happy and stop moaning. Quote Link to comment Share on other sites More sharing options...
M&S Posted August 16, 2010 Share Posted August 16, 2010 guess quickest solution this would be just turn the switch upside down Yup Quote Link to comment Share on other sites More sharing options...
Paul 200 TDI Posted August 16, 2010 Share Posted August 16, 2010 Seems to me moose that plasticbadger could be your neighbour, why not pop over Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted August 16, 2010 Share Posted August 16, 2010 Seems to me moose that plasticbadger could be your neighbour, why not pop over Not quite a neighbour, I live on the posh side of the forest, Moose lives on cheap side he does work about 2 miles away though... Quote Link to comment Share on other sites More sharing options...
moose Posted August 16, 2010 Author Share Posted August 16, 2010 Not quite a neighbour, I live on the posh side of the forest, Moose lives on cheap side he does work about 2 miles away though... How very dare you... just cos my locals like the pup in shameless and yours is like the one on the moors in American warewolf in London ok i will quit moaning and move the front switches round not all that bothered, but every disco i have been in the windows seen to work in a different way.. well on to more important things like hot gluing metal back into the body Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted August 17, 2010 Share Posted August 17, 2010 How very dare you... just cos my locals like the pup in shameless and yours is like the one on the moors in American warewolf in London Beware the moon, stick to the road.... Quote Link to comment Share on other sites More sharing options...
disco_al Posted October 11, 2010 Share Posted October 11, 2010 just cos my locals like the pup in shameless and yours is like the one on the moors in American warewolf in London even though the opening sequence was filmed on Hay Bluff and around Capel Y Fin...... but anyway, moine work by pushing the bottom of the switch to lower... Quote Link to comment Share on other sites More sharing options...
