lacrits68 Posted August 24, 2010 Share Posted August 24, 2010 hello! I wonder where to start looking: My 110 -97 makes an "metalish klonk sound" when hittin an bump, stone etc in 30mph and up. When hitting an pothole this sound and shake is not present, only with "Bumps". Sound is like "loose things" or there is play somewhere in the steering. Whwn hitting a "bumP" there is slight very short "shake" ( cant realy say its a "wobble) too! This happend only on left hand side frontwheel hit a "bump". ( my car is LHD) any ideas what might be wrong? recently changed chromeball and adjusted preload so it should be OK! anything else that migh cause this? cheers Jan Quote Link to comment Share on other sites More sharing options...
LR90 Posted August 24, 2010 Share Posted August 24, 2010 Panhard rod bushes/mountings might be worth a check? Also how good are the shock absorber bushes. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted August 25, 2010 Share Posted August 25, 2010 have a look at your left hand engine mount iv just had much the same . mine had split in half and the engine also bounced when under heavy load in the wrong gear . hope this helps Quote Link to comment Share on other sites More sharing options...
