Lars L Posted August 25, 2010 Share Posted August 25, 2010 I'm considering to "update" the heater on my '86 110 with a 200Tdi. As standard there is always flow of water through the heater core and asjustments of air temp is made by blending in cold air. Would installing a water valve as per Series III and control the flow of water from fully open to fully closed do any harm? Water will flow through the engine as before, it's just the part that goes to the heater that will be stopped. Quote Link to comment Share on other sites More sharing options...
sgnas Posted August 25, 2010 Share Posted August 25, 2010 Rather than shut the flow entirely could you just divert/bypass the heater matrix? Quote Link to comment Share on other sites More sharing options...
crwoody Posted August 25, 2010 Share Posted August 25, 2010 I can't see how it would do any harm, if the heater is set to cold then there should be no airflow over the heater matrix, so there's no additional cooling to the system anyway. To divert the flow and bypass the matrix would be a nice idea but would require a far more complex valving arrangement, it's debatable whether it would be worth it. Quote Link to comment Share on other sites More sharing options...
Maverik Posted August 25, 2010 Share Posted August 25, 2010 Its a little unclear what you're updateing it to do?? - is it that you can't stop hot/warm air comeing into the cab? Quote Link to comment Share on other sites More sharing options...
Lars L Posted August 25, 2010 Author Share Posted August 25, 2010 Surprisingly enough, I try to get the inside of my 110 warmer when it's cold outside. So I have bought myself a heater core for a Volvo 740 and am trying to install it into the heater box. First idea was to just replace the existing core, but I was mislead by the seller's web site. It's about 50 mm higher than the standard one, so it's a close call to not hit the bonnet. Then it struck me that I might rip out everything in the box and install the Volvo core horizontally as it is in a Volvo. When doing that, there will be no flap left to mix cold/warm air. Hence the need for a water valve. Quote Link to comment Share on other sites More sharing options...
Maverik Posted August 25, 2010 Share Posted August 25, 2010 Hmmm, I see, a little clearer now. If there is a bupass in the engine, then no need to bypass it again I suppose. A downside with putting a shut off valve is that you will get even less "instant" temperature control over your heating, it would take the time of the air flowing throught the matrix, to cool it and its contents... An idea I had, which is not much help to you now really, but I was thinking of maybe putting a pre-heat circuit into the plack flume box that feeds the fan, heeps of room to get a small matrix in there. that would definatly need a shut off valve though. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted August 25, 2010 Share Posted August 25, 2010 I suspect the engine uses the heater matrix as its coolant bypass for when the thermostat is closed, So if you did it, you'd need to use some sort of two way valve to ensure the water could still circulate around the heater loop when the matrix was shut off. Quote Link to comment Share on other sites More sharing options...
