DiscoHere Posted August 31, 2010 Share Posted August 31, 2010 Hi I just replaced the UJ in on my front prop shaft on my Discovery 1. I noticed the sliding portion of the propshaft was at the diff end when I took it off but as far as I can remember it should be at tht transfer box end. Am I correct or does it make any difference to the vehicle? Hugh Quote Link to comment Share on other sites More sharing options...
bear Posted August 31, 2010 Share Posted August 31, 2010 Hi DiscoHere, According to the Haynes manual "Ensure that the propeller shaft is refitted with the sliding joint towards the front of the vehicle (nearest the front axle)" Regards Quote Link to comment Share on other sites More sharing options...
DiscoHere Posted August 31, 2010 Author Share Posted August 31, 2010 Thanks Hugh Quote Link to comment Share on other sites More sharing options...
