dannyboi Posted August 31, 2010 Share Posted August 31, 2010 hey all quick question iv got a bit of a leak from the transfer box on my 2.5td 90 is there a common oil seal that goes or is it a case of taking it apart and seeing whats leaking ? thanks Quote Link to comment Share on other sites More sharing options...
gee1599 Posted September 1, 2010 Share Posted September 1, 2010 can you see where its leaking from ? front rear middle ?? Quote Link to comment Share on other sites More sharing options...
sharpy Posted September 2, 2010 Share Posted September 2, 2010 Hiya, Not sure if this will help but I have recently had a leak on my power steering and front diff, as a quick solution there are products on the market which i have used and stopped my leaks, on ebay there is a Lucas oil that you can put in gearboxes, engines etc which contain a mineral that penetrates the seals and small cracks and stops the leak, whilst also (it claims?) will be better than just normal oil. My power steering fluid was replaced with a brand bought from a moto-bits kind of place and its made by Comma, this has also worked andstopped the leak. Not sure how long a solution it will be but i had to do something for a quick fix, had both in for about a month and all seems fine, STP and most large well known manufacturers do similar products Paul Quote Link to comment Share on other sites More sharing options...
Marco Posted September 2, 2010 Share Posted September 2, 2010 hey all quick question iv got a bit of a leak from the transfer box on my 2.5td 90 is there a common oil seal that goes or is it a case of taking it apart and seeing whats leaking ? thanks Try to find where it's leaking from. Front and rear outpiy shaft seals easy to fix, cleaning breather also easy job but replacing seal / o-ring and more on intermediate shaft is much more work => remove complete unit and strip. Check this post: LT230 Transfer Box rebuild Cheers Marco Quote Link to comment Share on other sites More sharing options...
dannyboi Posted September 2, 2010 Author Share Posted September 2, 2010 thanks for the advise looks like the output shaft oil seal Quote Link to comment Share on other sites More sharing options...
