Part Number Request
bishbosh
I need to replace the brake manifold that sits on top of the rear diff of the Rangie.
I don't have a picture but it has two inpits from the rear :blink: and one output to each side.
It is a brasss casting and I've lunched the threads on one of the outputs :angry: . It would appear the previous owner had a brake line replaced and the T"£%er who did it cross threaded the brake fitting but got it to seal.
I come along to replace that brake line and of course there isn't enough thread left to get a puchase and it strips :angry::angry: .
Fittings are imperial.
Bluddy Land Rovers.
TIA
Not really.
All the in/outputs are horizontal and there is a hole through the casting so it can be bolted to the bracket on the diff housing.
It's sort of "T" shaped in plan, but the T is very squat.
Guest diesel_jim
Is it something like this ?
From VWP
has anyone got an IMPERIAL one of these kicking around they don't want?
I'm just building a "new" back axle for my project90-2 and i discovered to my "pleasure" this afternoon that the one i've got is a metric one.
swap for metric or beer tokens? B)
Guest diesel_jim
Jim,
Just make up the brake lines to fit what you have - I just had to do one end imperial, the other metric 'casue the caliper I ordered came metric :ph34r:
I though about maybe doing that, especially as the axle is sat on a trolley in my garage, it's nice and easy to get to, i just thought that it would be the lazy arsed way out of doing more work easier to get the union. :D
