Harness regulations
Tom.H
hope this helps, by the way all three point harness' have been banned for speed events
57.2.1. All vehicles must comply with K.2.1.2, K.3.1.2
(not plumbed in), K.5, K.6, K.8.
2.1. All seat safety belts must be must be complete
units sourced from a recognised manufacturer and
fitted in accordance with the manufacturers
instructions, MSA recommendations or FIA
requirements. (See FIA Drawing Nos. 253–42, 253–43,
253–44 and 253–45)
Seat belts, in the following specified configurations,
must be worn and be correctly adjusted at all times
during events:
2.1.1. Three point. One diagonal shoulder strap and
one lap strap, with three anchorage points on the
chassis/body shell or roll over bar of the vehicle on
either side and to the rear of the driver’s seat.
2.1.2. Four point. Two shoulder straps and one lap
strap, with four anchorage points on the chassis/body
shell or roll over bar of the vehicle. One either side of
the driver and two to the rear of the driver’s seat.
2.1.3. Six point. Two shoulder straps, one lap strap and
two straps between the legs, with six anchorage points
on the chassis/body shell or roll over bar of the vehicle.
One either side of the driver, two to the rear of the
driver’s seat (or one symmetrical for the two shoulder
straps) and two between the legs.
2.1.4. Where safety harnesses are mandatory it is
recommended that those described in 2.1.2. and 2.1.3.
are homologated by the FIA and carry their label.
2.1.5. It is permitted to make a hole in series production
seats to allow secure anchoring of seat belts.
2.1.6. All seat belts used on International events must
be homologated by the FIA, and carry their label.
2.1.7. It is not permitted to mix parts of seat belts. Only
complete sets as supplied by manufacturers should be
used.
2.1.8. Only one release mechanism is permitted on
each seat belt configuration and this must be available
for the wearer to operate whilst seated in the
competing position.
2.1.9. The anchorage points to the rear should be
positioned so that the strap from the shoulder is as
near horizontal as possible. It should not be located on
the floor directly behind the driver/co-driver.
2.1.10. Seat belts once involved in a serious accident
should be discarded as they are likely to have
stretched. Belts subjected to oil, acid or heat should be
replaced.
depending on the regs most clubs used to accept 50mm eg 2 inch widebelts.
some now ask for 3 inch shoulder belts and 2 inch lap belts.this is what we run in all the cars we use off road.
you also need to be able to unlock them when you are hanging upside down etc easily after an off.not all belts release easily as we found out last year.
In my mind for off road speed events you really want 75mm harnesses. Makes sense to get FIA but don't necessarily need to be in-date in the UK. One thing I would avoid is buying second hand, you never really know the history and as it says belts stretch in an accident!
Spoke to Mr Palmer( A MSA scrutineer) and for speed events FIA harnesses must be in date .nik
I'm certainly not going to argue with such an authority as Vic or his son, but I genuinely didn't think that was the case. I bought some homologated in-date harnesses to compete in France where they are mandatory as well as for international events in the UK, but I believe my old belts remain fine for club events here, right up to National A level.
My understanding seems to tally with the blue book snippet above. Rally events are different and do require in date harnesses. Note that the snippet posted here is only the general harness reg and needs to be read in conjunction with the technical part of the off road regs.
hi I'm currently training as a scrutineer under Vic and you are right and was misinformed by Mark on Thursday or i asked the question wrongly most likely.
this is from cross country events , technical regulations , all vehicles , to find the other regs .
witch there is no mention of dates .
