Warthog Posted September 2, 2010 Share Posted September 2, 2010 Looking for a supplier for the Air Pump that sits on the side of an air operated jack? Like the ones in the linky: http://www.mytoolstore.com/astro/asthyd01.html I may well have the in-correct name for the item though? Cheers Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 2, 2010 Share Posted September 2, 2010 For the ones in the link something like an ARB pump should work. I guess any pump/compressor would work, you just need the right connector. But the ones I think of as air jacks are the big bag ones you inflate from the exhaust Quote Link to comment Share on other sites More sharing options...
GBMUD Posted September 2, 2010 Share Posted September 2, 2010 An ARB type compressor will supply air but those jacks use air to operate a hydraulic pump which lifts the jack. Chris Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 2, 2010 Share Posted September 2, 2010 Air over hydraulic ones aren't true air jacks. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted September 2, 2010 Share Posted September 2, 2010 Air over hydraulic ones aren't true air jacks. Have a cigar. They are, as the OP suggested, air operated hydraulic jacks. Chris Quote Link to comment Share on other sites More sharing options...
Warthog Posted September 2, 2010 Author Share Posted September 2, 2010 Cheers Guys, But no one has a supplier to recommend then? Quote Link to comment Share on other sites More sharing options...
steve b Posted September 2, 2010 Share Posted September 2, 2010 Hi Mark I'd try the jack makers for a start , Sealey supply that type of jack , HeadOffice in Bury St Edmunds. As for the cyl itself they are some sort of auto cycling air cylinder I believe with built in valving, have you looked at Martonair or Siemens for an Industrial equivalent? cheers Steveb Quote Link to comment Share on other sites More sharing options...
Warthog Posted September 3, 2010 Author Share Posted September 3, 2010 Hi Mark I'd try the jack makers for a start , Sealey supply that type of jack , HeadOffice in Bury St Edmunds. As for the cyl itself they are some sort of auto cycling air cylinder I believe with built in valving, have you looked at Martonair or Siemens for an Industrial equivalent? cheers Steveb Cheers Steve, Will give a few places a call. Funny thing is, not know the exact name of this type cylinder/pump? Make for entertaining conversation over the phone :-) Quote Link to comment Share on other sites More sharing options...
