treebloke Posted September 8, 2010 Share Posted September 8, 2010 Nice forecast, wet all week and rain on Saturday then showers on Sunday. Anyone know if theres a snack bar. Quote Link to comment Share on other sites More sharing options...
markyb Posted September 8, 2010 Author Share Posted September 8, 2010 Rob look at you with the push lazor cutter. nice jimny , look forward to seeing that at round 4 , right wheres that hydro steer or fiddle brakes to get in class 1 Quote Link to comment Share on other sites More sharing options...
saley Posted September 9, 2010 Share Posted September 9, 2010 Rob look at you with the push lazor cutter. nice jimny , look forward to seeing that at round 4 , right wheres that hydro steer or fiddle brakes to get in class 1 Just take your screen out, that will be enough to make you class 1. Quote Link to comment Share on other sites More sharing options...
Rob Butler Posted September 9, 2010 Share Posted September 9, 2010 I think you'll find that the only things that would make you class 1 are... - Full Hyrdo steer - Rear Steer screen or fiddle brakes makes no odds... fiddles are allowed in any class... and if you have no screen you must have mesh, in any class... The only other thing that would make you class 1, is if they decide your truck looks more menacing than the others in your class... then they'll just chuck you in class 1 anyway... we'll that's what happened to us at Walters Arena a few years ago... Quote Link to comment Share on other sites More sharing options...
D3DPE Posted September 9, 2010 Share Posted September 9, 2010 Rob.... I was told last year after some one brought it to the attention of the scruitneers when I was running no screen that it wasn't allowed in class 2, you had to have a windscreen....... So I had to fit one for the next event..... Dan Quote Link to comment Share on other sites More sharing options...
Rob Butler Posted September 9, 2010 Share Posted September 9, 2010 With our buggy... "class 1 " we was told by the scrut's that if we did not have a screen / mesh we could not compete at all... Same old story... none of them are on the same page... Quote Link to comment Share on other sites More sharing options...
najw Posted September 9, 2010 Share Posted September 9, 2010 Class Eligibility Regs Class 1: Unlimited Modifications. Vehicles may be equipped with any combination of winch AND diff locks. A mechanical link is not required between the steering wheel and the steered wheels. Class 2: Modified. Vehicles may be equipped with one or more of the following: Multiple Winches, Front and/or rear diff locks. Vehicles must be fitted with a windscreen. Four Wheel steering is not permitted. Class 3: Limited Modifications. Vehicles may be equipped with one winch. Traction aids may only be used if original factory fitted equipment. Vehicles must be fitted with a windscreen. Four Wheel steering is not permitted. Technical Regs 19. WINDSCREENS AND SIDESCREENS If fitted to have windscreens of either laminated glass or plastic, of a minimum thickness of 4mm. Plastic sidescreens, where fitted, should also have a minimum thickness of 4mm unless fitted otherwise by the original manufacturer. If a windscreen is not fitted a steel mesh screen must be fitted in its place. Definitely not on the same page, nor even in the same document :rolleyes: To answer Treebloke's question - there will not be a catering van on site at this event. Quote Link to comment Share on other sites More sharing options...
sam coulton Posted September 9, 2010 Share Posted September 9, 2010 nice tube work on the jimny rob what class is that being built for Quote Link to comment Share on other sites More sharing options...
Rob Butler Posted September 10, 2010 Share Posted September 10, 2010 The tube Jimny will be class 3 for the time being... mid mounted GP84, 12v running with 24v shoved through it... Yota 70 axles, 3 linked front / rear, 37" creepey crawlers, 6.6.1 T-case. We'll run it like that until the end of next year whilst we build/compete in the new racer... and then the Jimny will get lockers, Hydro steer, quad-cam V6 and airshocks ect... then it'll be class 1... Quote Link to comment Share on other sites More sharing options...
najw Posted September 10, 2010 Share Posted September 10, 2010 Seems with my usual efficiency I booked a caterer at the start of the year. So there Will be a caterer on Sunday Quote Link to comment Share on other sites More sharing options...
JST Posted September 10, 2010 Share Posted September 10, 2010 Well, i hope you all have a good weekend, the first i will miss in 2 yrs i guess. Mark be gentle on Nick, dont worry to much about overall result, first in class would be ok. Quote Link to comment Share on other sites More sharing options...
markyb Posted September 10, 2010 Author Share Posted September 10, 2010 Thought you couldnt have fiddle brakes in class 3 as can be seen as a traction aid? anyway not much more to do to the motor. see you there sunday Quote Link to comment Share on other sites More sharing options...
jil6939 Posted September 10, 2010 Share Posted September 10, 2010 C'mon Mark, it's not all about trophies.... Bit sick to miss this one because I've no events for about 7 or 8 weeks now..... Hell, I might even paint it ..a bit, I suppose... Have a great weekend people..and good luck Chris Put a rope on it first!!! Quote Link to comment Share on other sites More sharing options...
treebloke Posted September 10, 2010 Share Posted September 10, 2010 Seems with my usual efficiency I booked a caterer at the start of the year. So there Will be a caterer on Sunday Sound, it takes half hour to cook a bacon & egg sarnie on a Sunday morning. Gives me time to polish the truck instead. Quote Link to comment Share on other sites More sharing options...
sam coulton Posted September 10, 2010 Share Posted September 10, 2010 The tube Jimny will be class 3 for the time being... mid mounted GP84, 12v running with 24v shoved through it... Yota 70 axles, 3 linked front / rear, 37" creepey crawlers, 6.6.1 T-case. We'll run it like that until the end of next year whilst we build/compete in the new racer... and then the Jimny will get lockers, Hydro steer, quad-cam V6 and airshocks ect... then it'll be class 1... nice 1 i can see what the standard is then for nxt year best get cracking on my new truck then Quote Link to comment Share on other sites More sharing options...
