dicsosfa Posted September 2, 2010 Share Posted September 2, 2010 hi posting this for a friend as he does not have internet access so here goes he has a 1991 tdi defender with a knackered steering box and he wants to know if he can fit a disco one, i think it will fit but he will have to change the drop arm,but i am sure someone correct me if i am wrong so i said i would ask someone with more knowledge so here i am. i hope you can help me Roy Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 2, 2010 Share Posted September 2, 2010 might soon have a spare defender 4 bolt for sale.......very slight weep from the bottom seal but other than that its perfect. I seal kit or one of those fix liquids would sort it out. I'm changing it as i'm off round the world. A disco one has a different lock to lock as far as i know but will fit as far as i've been told. You might need to change to drop arm though. One of the grown ups will confirm. The quicker disco PAS lock to lock is seen as beneficial by many, retro fitted on a defender. Quote Link to comment Share on other sites More sharing options...
white90 Posted September 2, 2010 Share Posted September 2, 2010 hi posting this for a friend as he does not have internet access so here goes he has a 1991 tdi defender with a knackered steering box and he wants to know if he can fit a disco one, i think it will fit but he will have to change the drop arm,but i am sure someone correct me if i am wrong so i said i would ask someone with more knowledge so here i am. i hope you can help me Roy as long as it is the same "bolt" as the one there yes he can the number of bolts on the top ID the box 3-4-6 4 being the strongest apparently. Don't fit a a leaking one as it is a total waste of time & ££ Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 3, 2010 Share Posted September 3, 2010 The drop arm can be a bugger to remove - but the disco one has a normal ball joint making it worth keeping IMO. You'll need to replace the drag link with the longer Disco one and get a small bracket to hold the steering damper. Well worth doing I think. Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted September 4, 2010 Share Posted September 4, 2010 I've done exactly this to my 110 earlier this year. I've fitted a PAS box from our scrapper 300TDi Discovery to the 1989 110. It means you lose the steering damper, you can get a kit to fit a clamp on damper if you feel you need it. To be honest I can't tell the difference without one. Will Quote Link to comment Share on other sites More sharing options...
