bad oil leak
Which side of the engine does your dad think it's coming from? as mine does the same as it's leaking a little bit from where the oil filter housing attaches to the block but not too much to be worried by
John
I concur with Mo check the turbo oil feed and also I think if that's not the case then look at the oil drain pipe where the union fit's onto the base of the turbo and where it fit's onto the block as I've had oil leaking from there before too
HTH
John
 Share
