tonycougar Posted September 6, 2010 Share Posted September 6, 2010 I have replaced my standard 90 door mirror with a military wolf one so that it improves the rearward vision during towing (which I do a lot of). It does the job, but the tension on the spring is not enough to stop it folding back under speed and in wind. It appears as though the tension can be adjusted but when I try it won't budge. Thought I'd check before I apply the usual brute force and ignorance. It is a new mirror so it shouldn't be seized. Can the tension be adjusted? Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted September 6, 2010 Share Posted September 6, 2010 It should be just a case of tighting the bolt thus compressing the spring.....try to loosen it off first....might need a few washers under the head of the bolt. Quote Link to comment Share on other sites More sharing options...
Litch Posted September 6, 2010 Share Posted September 6, 2010 Is that the Spafax one, they are advertised as being fitted to practically all current MOD vehicles including LR? I have the heated ones on my 90 and one of them was always moving back at high speed, as soon as you slowed doen it went back into the normal position. I took the reflector off (I won't call it glass as it isn't) and tightened the central nut slightly (this compresses a spring), the mirror isn't as adjustable any more but at least it holds its position ok. Quote Link to comment Share on other sites More sharing options...
tonycougar Posted September 7, 2010 Author Share Posted September 7, 2010 Is that the Spafax one, they are advertised as being fitted to practically all current MOD vehicles including LR? I have the heated ones on my 90 and one of them was always moving back at high speed, as soon as you slowed doen it went back into the normal position. I took the reflector off (I won't call it glass as it isn't) and tightened the central nut slightly (this compresses a spring), the mirror isn't as adjustable any more but at least it holds its position ok. Quote Link to comment Share on other sites More sharing options...
tonycougar Posted September 7, 2010 Author Share Posted September 7, 2010 No idea what make it is. Now I know it should be adjustable I shall try a bit harder. Thanks fella's Quote Link to comment Share on other sites More sharing options...
