pucela Posted September 6, 2010 Share Posted September 6, 2010 Have 02 defender tdi, engine cuts out while driving, completly dies, battery is fine, it takes ages to fire up, i know air is leaking back into fuel is this enough for it to cut the engine off while driving, thanks need help Quote Link to comment Share on other sites More sharing options...
adam300Tdi90 Posted September 6, 2010 Share Posted September 6, 2010 Definitely TDI? are you in RestOfWorld? It's normally a TD5 at this age... Quote Link to comment Share on other sites More sharing options...
ozzie1989 Posted September 6, 2010 Share Posted September 6, 2010 On the basis you have a TD5 (not TDI)... Measure the fuel pressure at the Fuel Temp Sender, you should be seeing a constant 4bar at all times with the engine running. It does sound like you are getting air in the system, and with a TD5 engine this will cause you all sorts of problems as it runs a high pressure fuel system. What does your fuel pump sound like when you initially put the ignition on? If it isn't a constant whirr of the pump, but changes and gurgles then you do indeed have air. It could also be a sign of the fuel pump on it's way out - as these do go quite often. Unfortunately they are located on the top of the fuel tank and you'll need to remove or cut your floor to get at it (unless you want to remove the tank). Quote Link to comment Share on other sites More sharing options...
pucela Posted September 6, 2010 Author Share Posted September 6, 2010 On the basis you have a TD5 (not TDI)... Measure the fuel pressure at the Fuel Temp Sender, you should be seeing a constant 4bar at all times with the engine running. It does sound like you are getting air in the system, and with a TD5 engine this will cause you all sorts of problems as it runs a high pressure fuel system. What does your fuel pump sound like when you initially put the ignition on? If it isn't a constant whirr of the pump, but changes and gurgles then you do indeed have air. It could also be a sign of the fuel pump on it's way out - as these do go quite often. Unfortunately they are located on the top of the fuel tank and you'll need to remove or cut your floor to get at it (unless you want to remove the tank). Getting 4bar thats been ruled out, fuel pump is making lots whirring noises, maybe the pump needs replacing thanks i'll soldier on. Quote Link to comment Share on other sites More sharing options...
