callum Posted September 6, 2010 Share Posted September 6, 2010 trying to find the part no. for the plastic bushes/shims that isolate the door hinges from the bulkhead and door. td5 hinges are a bit bigger and rounder so the old parts don't fit. from an older thread, i see the part no. for the shim between hinge and bulkhead is BDC710040 i can't see anywhere the part no for the shim between the hinge and door. maybe its the same part, but on the old hinges they were a different shape. thanks for your help callum Quote Link to comment Share on other sites More sharing options...
western Posted September 6, 2010 Share Posted September 6, 2010 My Microcat only shows the MWC1898 part number for the hinge to door plastic spacer/shim. Quote Link to comment Share on other sites More sharing options...
callum Posted September 6, 2010 Author Share Posted September 6, 2010 hmm, maybe the part does not exist for td5 models, certainly does for pre td5 models. i assumed the shim was to prevent corrosion. that being the case, i think i'll just order double and see if the bulkhead. some work with the scalpel will sort it if its a problem i suppose. anyway, thanks for your help ralph, that was a pretty quick response. Quote Link to comment Share on other sites More sharing options...
