free wheeling hub removal
dixe
Don't really need????
The only thing you dont really need are the bloody FWH - they have no place on a landrover IMHO. They're a complete pita, casue more problems tan they solve, and are an inherantly weak link. You cant get parts for them, and alot of people on here have blown them up!
I threw mine away years ago!
Jon
I'm planning on removing the free wheelers from my series 3. It has the later type of axle. Which parts will I need to fit to go back to how it should be?
2 drivemembers, gaskets, perhaps the 2 castelled nuts that hold the halfshaft to the drivemember (it's been a while that I had a Rover axle in my hands) and I guess, depending on the FWH's you've got that you might need new (shorter) bolts.
I rather like the way they stick out, and add character to the front wheels! why did they bother making them, and why did people still carry on buying them, if they were no good? mine were already fitted, don't seem to have any probs with them so far fingers crossed!
i tried to take one off my 2a when i first got it to replace the swivel bearings, i undid the bolts and used leaver bars to prise it off but it didnt seem to want cum off so i put it back and took shims out to get it thru the mot
is it just a case of using more force to remove it or is there any other way, i think there selecto make?
Selectro? (famed for leaking right from new :) )
Remove the chrome cap (3-or-4mm hex), Some of the guts of the hub will come off and then there's a funny nut thingy, which has to be unscrewed from the end of the shaft that you can now see. The sourrounding bolts that hold the hub main body to the vehicle hub can then be undone and the reamainder of it can be removed. This is from memory, so I could be entirely wrong.
Les.
  • 10 years later...
3 hours ago, BoristheS3 said:
3mm hex is rounded in the bolt head.  Any suggestions on how to remove?
Torx bits can grip quite well in a damaged hex - especially if you buy a cheap sacrificial one you're afraid to hammer into the hole :ph34r:
Failing that drill the heads off. The body of the thing will only be getting skipped when you remove the FWH's and go back to standard drive members anyhow...
  • Like 1
On 9/9/2010 at 12:44 PM, FridgeFreezer said:
Either will be fine, remove them, throw them in the bin and put normal flanges back on.
I never understand why peeps say this i have the AVM ones on mine and although i don't off road it i do turn them on and off every now and then with them locked in i find the steering heavy but when they are off i find the steering light plus when they are off the landy pulls away that little bit easier so not dragging all the drive weight in the front axle around all the time.
The first time you get bogged because you forgot to engage them when leaving the road you'll realise why so many people don't like them.
There are benefits for people who use their 4x4 on tarmac only, but the benefits for vehicles that work regularly are outweighed by the negatives.
the Belgian army had a really good solution if you only drive on tarmac , remove the whole front axle and drive shaft, put a rigid beam axle in place and fit a limited slip rear diff .....👀
Yes i'm guilty of that myself forgetting to put them in
I had some and I recorded the fuel consumption over the same route over a year.  It made not a jot of difference, and I never noticed any change in steering either.  They did split their o-rings and leak, despite having been fitted brand new, as well as present the problem of getting filthy to get out and lock them when unexpectedly in grotty conditions.
The only benefit I have ever been swayed by is that of being able to select 2wd and drive home with a broken diff or shaft for a repair in better conditions, but unless you regularly put the vehicle through very hard off-road driving, in which case a pegged diff and better shafts would be a wiser mod, how often is that likely to happen?  I’m firmly in the “they belong in the scrap pile” camp.
