margan Posted September 9, 2010 Share Posted September 9, 2010 Hi Guys I am in the process of buying a 2003 freelander with 32,000mls, 2.5v6 ES, A great car except when it changes gear there is quite a voilent thud..then drives ok until the next change, the current owner says his daughter when through some flood water & then this problem started. Any body got any thoughts or history of this type of thing, it nearly feels like something is loose.... Quote Link to comment Share on other sites More sharing options...
Dorsetfreelander Posted September 9, 2010 Share Posted September 9, 2010 Might be worth having a look at this site and/or contact them before buying. This could be an expensive problem. http://www.ashcroft-transmissions.co.uk/ Quote Link to comment Share on other sites More sharing options...
mrtibbs Posted September 11, 2010 Share Posted September 11, 2010 Unless it is extremely cheap I wouldn't touch it to be honest.... Good luck Keith Quote Link to comment Share on other sites More sharing options...
defv890 Posted September 11, 2010 Share Posted September 11, 2010 hi there is a bulitin on gtr for that fault if you can get the fault codes read then that might help you out. Quote Link to comment Share on other sites More sharing options...
margan Posted September 11, 2010 Author Share Posted September 11, 2010 hi there is a bulitin on gtr for that fault if you can get the fault codes read then that might help you out. Thanks for the reply...GTR? Quote Link to comment Share on other sites More sharing options...
viorelluta Posted September 17, 2010 Share Posted September 17, 2010 A similar symptom on a VW Passat led to the following cause: the "valves block" needs to be replaced (the hydraulic actuators). The cost is aronud 2,000 eur. I like auto gearboxes, but when they break, they cost you a lot... viorel Quote Link to comment Share on other sites More sharing options...
margan Posted September 27, 2010 Author Share Posted September 27, 2010 Update: Got the car plugged into a diagnostic machine, turns out the oxygen sensor is gone (drinking fuel) and they say it will affect the gear change as the engine management is all over the place with the faulty sensor on order so let wait and see. Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted September 28, 2010 Share Posted September 28, 2010 it will be interesting to see if it fixes the gearbox Quote Link to comment Share on other sites More sharing options...
Disco_Mikey Posted September 30, 2010 Share Posted September 30, 2010 If you do need an auto box, I am currently breaking an automatic TD4 Quote Link to comment Share on other sites More sharing options...
margan Posted October 5, 2010 Author Share Posted October 5, 2010 Update: Got the car plugged into a diagnostic machine, turns out the oxygen sensor is gone (drinking fuel) and they say it will affect the gear change as the engine management is all over the place with the faulty sensor on order so let wait and see. Great news, new oxygen sensor fitted and the car is now driving perfect. Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted October 7, 2010 Share Posted October 7, 2010 That is one worth remembering Quote Link to comment Share on other sites More sharing options...
