hattymender Posted September 11, 2010 Share Posted September 11, 2010 Hatty's indicator relay is playing up. Well, a bit. (Most of Hatty is a 1988 110) In normal use it gives one flash of the trailer light along with the normal indicator warning then works normally. With a trailer plugged in there's no trailer warning. But it works fine. Now I have my old loom following a bulkhead swap with a full set of relays. And I'm sure it's the large transparent blue one full of wiggly amp stuff? But a bit of reassurance would be nice before I brave the elastic-tricity stuff:) Quote Link to comment Share on other sites More sharing options...
western Posted September 11, 2010 Share Posted September 11, 2010 And I'm sure it's the large transparent blue one full of wiggly amp stuff correct & most likely has Hella printed on it, should e attached to the bulkhead sie of the fusebox metal panel with a screw or bolt, not clipped along the bottom like the other relays. Quote Link to comment Share on other sites More sharing options...
hattymender Posted September 11, 2010 Author Share Posted September 11, 2010 Thank you kind sir! Quote Link to comment Share on other sites More sharing options...
