6735DXB Posted September 13, 2010 Share Posted September 13, 2010 A small piece of plastic, I think from the broken air vent arm above, dropped onto centre console and into the open keyhole slot in the ignition. I know this with hindsight - and accept stupidity - but pushed in key before realising the error or the reason!! Now key will not seat properly in the lock (proud by about 2mm) and so cannot switch on, or do much of anything - even recovering it was a massive undertaking! Is this a fixable problem that anyone else has encountered or is the end of the world as related to me by local part-changers, who now want to replace the steering module and codes, et al!!? Cheers, from "Broke n Perplexed" in Dubai. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted September 13, 2010 Share Posted September 13, 2010 A small piece of plastic, I think from the broken air vent arm above, dropped onto centre console and into the open keyhole slot in the ignition. I know this with hindsight - and accept stupidity - but pushed in key before realising the error or the reason!! Now key will not seat properly in the lock (proud by about 2mm) and so cannot switch on, or do much of anything - even recovering it was a massive undertaking! Is this a fixable problem that anyone else has encountered or is the end of the world as related to me by local part-changers, who now want to replace the steering module and codes, et al!!? Cheers, from "Broke n Perplexed" in Dubai. Assuming you can find a locksmith they will have tools and patience to dig out the bit of plastic. If you can't find one it would probably still be cheaper to fly one out than pay the dealer to replace and recode... Quote Link to comment Share on other sites More sharing options...
