FFR Posted September 13, 2010 Share Posted September 13, 2010 Hi, I allways try to be self-sufficient when searching for parts, but my landy is an hybrid and sometimes is a bit complex not to make an error when ordering parts (I did it a couple of times). I'm converting it from LHD to RHD. It was a 1991 V8, but the previous owner put a 300tdi in 2001. On the other hand, I'm installing discs on rear and vented discs in the front axle, so (maybe) the current master cylinder will not provide enough flow. - Which are the part numbers of the pipes going from the master cylinder to the chassis (well, to a small part attached to the bulkhead) ? - Can I upgrade the master cylinder to a 300tdi type, without changing the brake lines? Do I have to change the servo, too? Do I have to change the pedal assembly to accomodate the new servo? Thanks a lot in advance, Carlos My master cylinder: Brake lines coming from the master cylinder are attached to this small part: The brake lines that I need to purchase are highlighted in red: Last picture was downloaded from the internet ages ago, it is not really mine. Quote Link to comment Share on other sites More sharing options...
western Posted September 13, 2010 Share Posted September 13, 2010 easier to buy kunifer brake pipe & end fittings & make your own brake pipes. later master cylinder/servo should be OK on your existing brake pedal assembly. Quote Link to comment Share on other sites More sharing options...
FFR Posted September 13, 2010 Author Share Posted September 13, 2010 easier to buy kunifer brake pipe & end fittings & make your own brake pipes. later master cylinder/servo should be OK on your existing brake pedal assembly. Hi Ralph, Yes, you are right... do you know whom can I buy the hardware & tools from ? I tried Draper Tools and other online retailers unsuccessfully. Thank you for your time, you are allways of a great help. Carlos Quote Link to comment Share on other sites More sharing options...
FFR Posted September 13, 2010 Author Share Posted September 13, 2010 I found it ! http://www.vehicle-wiring-products.eu/VWP-onlinestore/brakepipe/brakes.php Carlos Quote Link to comment Share on other sites More sharing options...
western Posted September 13, 2010 Share Posted September 13, 2010 That'll do the job. Quote Link to comment Share on other sites More sharing options...
