crclifford Posted September 13, 2010 Share Posted September 13, 2010 So, I have a new Td5 Windscreen washer bottle, but the electrical connectors to the pumps are different to my old ones. The new ones are a rectangluar shape rather than the 2 seperate connectors on each pump. (photo will be added when i get a chance). So does anyone know the part number for the connectors? Also, Anyone know what the part numbers are for the rubber sealing rings for the gauges in the binnacle? Many thanks Quote Link to comment Share on other sites More sharing options...
western Posted September 14, 2010 Share Posted September 14, 2010 part numbers are for the rubber sealing rings for the gauges not listed in microcat as a seperate part. perhaps http://www.merlinmotorsport.co.uk/ or https://www.europaspares.com/ can advise further, both supply 52mm VDO Vision gauges, which are the same size as the LR gauges. the electrical connectors to the pumps are different to my old ones again, not listed as seperate part by LR, as these are part of the main dash/engine bay wiring harness. http://www.autosparks.co.uk maybe able to assist. Quote Link to comment Share on other sites More sharing options...
crclifford Posted September 14, 2010 Author Share Posted September 14, 2010 Ralph, Many thanks for the links, will give those places a go..otherwise, it looks like i'll have to get a new wiring harness..hoping that the part AMR2979 will have the correct ends and i can merge the two together. Chris Quote Link to comment Share on other sites More sharing options...
PaulMc Posted September 15, 2010 Share Posted September 15, 2010 52mm 'O' Rings for gauges are available from here - http://www.holden.co.uk/displayproduct.asp?pCode=070.040 52mm - O Ring for 52mm Gauges Spare O Ring for 52mm gauges. This O Ring fits between the rim and the dashboard. Part-no. 070.040 Size: 52mm Pack-size: each Stock: In stock Price: £0.70 (ex VAT) The washer pump connectors are AMP Econoseal, available here - http://www.polevolt.co.uk/acatalog/info_ESC2F.html On the Land Rover loom, the windscreen washer pump connector is Red and the rear screen washer pump connector is Black. On AMP Econoseal connectors, the different coloured connector shells are used to denote different circuits, they are not keyed differently and will all interconnect with each other. So having two black connectors won't make any difference, but you'll have to make sure that you've connected them to the correct washer pump or your washers will work back-to-front . Quote Link to comment Share on other sites More sharing options...
crclifford Posted September 15, 2010 Author Share Posted September 15, 2010 Paul, Many thanks All ordered now! Quote Link to comment Share on other sites More sharing options...
western Posted September 15, 2010 Share Posted September 15, 2010 Thanks Paul for assisting Quote Link to comment Share on other sites More sharing options...
carolyny476 Posted September 21, 2010 Share Posted September 21, 2010 PaulMc - Thanks so much! Exactly what I was looking for. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted September 21, 2010 Share Posted September 21, 2010 PaulMc - Thanks so much! Exactly what I was looking for. Glad to have been of assistance . Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 21, 2010 Share Posted September 21, 2010 The washer bottle pump connecters on the TD5, are part of the LH wing harness rather than the engine harness. HTH Mo Quote Link to comment Share on other sites More sharing options...
