puma Posted September 14, 2010 Share Posted September 14, 2010 I'm new to the group so Hi to everyone. I was wandering if anyone can help me - my Defender (a 2007 puma) has an error code P0404 which translates as EGR flow CHT Range/performance, whatever that means! Basically I noticed it losing power as I pulled away in, it continues to 'splutter' but loads of accelerator overcame the power loss, it was intermittent but still annoying and I dont want to risk towing with this loss of power. Now a couple of days later it seems more noticeable (it souns like its miss-firing) Does anyone know if this is an easy fix (I'm ok with a spanner) but havent got a clue where to start. Any help will be appreciated. thanks Puma Quote Link to comment Share on other sites More sharing options...
Tim_NZ Posted September 14, 2010 Share Posted September 14, 2010 Sounds like the EGR valve isn't working correctly, not an uncommon problem unfortunatly. You could try pulling it off and cleaning it... I just let my one rev for a bit ocassionally, ie driving at 100km/h in 5th instead of 6th for a bit which seems to stop it sticking so much. Cheers, Tim PS Ultimate solution would be to blank the egr system, but unfortunatly this causes the DTC light (check engine) to come up on the dash. Quote Link to comment Share on other sites More sharing options...
puma Posted September 14, 2010 Author Share Posted September 14, 2010 Thanks Tim Is it an easy job to pull it off? (i'm not even sure where it is!) cheers James Quote Link to comment Share on other sites More sharing options...
Tim_NZ Posted September 15, 2010 Share Posted September 15, 2010 It's in a pig of a spot on the passenger side, (assuming RHD), of the engine. Have a look at this thread, there's heaps of info on the EGR system in it: http://www.defender2.net/forum/topic3115.html Cheers, Tim Quote Link to comment Share on other sites More sharing options...
