WOLF ANTI ROLL BARS
JonGM
HI
Can anyone help me!
I have been informed that the Anti Roll bars fitted to the Wolf 130, 110 & 90's has a higher/stiffer torsional action than standard.
IS this correct? Did they fit any to the rear?
I am after definitely one for the front but would also like a rear one.
Cheers
Jon
I have a 110 HD ex utillity which went through Special vehicles and has anti roll bars front and rear, when I had to replace the bushes on the rear anti roll bar for the MOT I had real hassel trying to get them as the anti roll bar is of a larger diameter than normal or so I found out after buying the normal size ones.
I'd guess that the larger diameter has greater resistance but I'm sure someone who knows better will be along shortly.
Yes much stiffer if it's thicker. I'm surprised they dodn't use the same thickness as the front TBH, I think that's what scorpion did. The figure you need to consider is called first moent of area, damned if I can remember how to work it out but it's just a littl ebit more complicated than comparing the cross-sectional area of the 2 types.
As for stiff roll bars, anyone seen the X-Eng disconnecting rear ARB?
  • 2 months later...
  • 2 months later...
