ivanlrlukic Posted September 17, 2010 Share Posted September 17, 2010 Is it possible to mount older steel wheels (Rostyle) to RRC of the nineties? Studs / nuts / bores concerned. Regards, Ivan. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 17, 2010 Share Posted September 17, 2010 Yes. You will need a set of wheel nuts though if you currently have alloys. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted September 17, 2010 Share Posted September 17, 2010 You don't "need" new wheelnuts because the alloy nuts are designed to hold a steel as well in case of a cheapo steel spare. They do look daft though. Steel wheel will also be narrower so you can't run the wider tyres. I think they are 6 inch rather than 7 inche alloys. Could be wrong. Quote Link to comment Share on other sites More sharing options...
