JonB Posted September 18, 2010 Share Posted September 18, 2010 Is there more than one type of thermostat for the 200tdi (defender housing). from my parts books i can only see one type. I Bought one a while back & it had a rubber seal ring, the supplier said there are 2 different types & to remove the rubber ring. Did this & was never that happy with the engine temperature, now having replaced the block its running erratic temperatures & with further investigation the out on the rad is cold. I will remove the thermostat tomorrow as a temporary measure & check the rads good... But want to make sure i get the correct thermostat to bung back in. Jon. Quote Link to comment Share on other sites More sharing options...
western Posted September 18, 2010 Share Posted September 18, 2010 the correct stat is a 88 degree LR Genuine part number ERR2803 Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 18, 2010 Share Posted September 18, 2010 Genuine Part is a tenner, fit and forget! http://www.brit-car.co.uk/product.php?xProd=84799 Quote Link to comment Share on other sites More sharing options...
JonB Posted September 18, 2010 Author Share Posted September 18, 2010 Thanks... God knows what the guys in the expensive landrover dealer sold me then! (quoted £150 2 change a front prop uj!) will get over to my preferred supplier (Christian Auto's in Bristol) & bung one in (providing test without stat is ok) Jon. Quote Link to comment Share on other sites More sharing options...
