Bobs Posted September 20, 2010 Share Posted September 20, 2010 Can anyone help me identify the source of a BMW 2.5 Diesel engine? I was told it came from a Range Rover, but I have my doubts. The engine numbers I have located are; 22508652 256TI 2245249 Is there anything else I can look for? Thanks in advance Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted September 20, 2010 Share Posted September 20, 2010 In the Workshop Manual, Introduction, Location of Identification Numbers, it says Engine serial number - BMW Diesel engine Stamped on the LH side of the cylinder block above the sump. There is no picture, but my 1995 MY engine number has 9 digits, starting 322 I cannot find anything in the Workshop Manuals or Technical Bulletins which list the number range of BMW engines fitted to Range Rovers. I don't recall a physical difference that shouts Land Rover instead of BMW. There is always a possibility that number lists exist in the BMW world, where the engine is classed, IIRC, as the M51 engine. The same possibility exists in the Vauxhall world, for the engine used in the Omega. If your engine appears in those lists it's bad news, assuming you want a Land Rover sourced engine. HTH Quote Link to comment Share on other sites More sharing options...
