nickt Posted September 20, 2010 Share Posted September 20, 2010 in a few days i got to replace the front output bearing on my transfer box how have you guys been getting the bearing out i dont have an internal bearing puller cheers Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 20, 2010 Share Posted September 20, 2010 Take a look in the tech archive. Lots of useful stuff in there............ http://forums.lr4x4.com/index.php?showtopic=25053&st=0entry254775 Quote Link to comment Share on other sites More sharing options...
Briarston Posted September 21, 2010 Share Posted September 21, 2010 Take a look in the tech archive. Lots of useful stuff in there............ http://forums.lr4x4.com/index.php?showtopic=25053&st=0entry254775 I did it, for the first time, guided by this write up. Quite straightforward. Instead of driving the shaft out as shown, I refitted the flange, threading on the nut about halfway, and put two spacers of suitable thickness(one each side)between the flange and the t/box nose. Tightening the nut pulled the shaft and bearing. This needs to be done two or three times as the amount pulled each time is small. When the bearing was flush with the end of the housing a quick tap with hammer and bar popped it right out. Not a job to be afraid of! Quote Link to comment Share on other sites More sharing options...
