LR NUT Posted September 20, 2010 Share Posted September 20, 2010 Hi, Does anybody know what the best type of bond to use to bond a strip of rubber to the door seal? I have tried the following so for but had no luck; Super glue Araldite Extra strong double sided tape number plate pads None of these seem to make the rubber strip bond to the door seal of the freelander cheers Quote Link to comment Share on other sites More sharing options...
disydave Posted September 20, 2010 Share Posted September 20, 2010 Hi,try land rover glue,it works every time for me ...Black mastik... as used by window fitters "the rubber type" Quote Link to comment Share on other sites More sharing options...
digiboy Posted September 21, 2010 Share Posted September 21, 2010 Sika Sikaflex, same stuff as windscreens are bonded with, great range, just find the correct one for the job. http://gbr.sika.com/print/uk-home/ind-uk-home/ind-uk-customer/ind-uk-customer-marine/ind-uk-customer-marine-products2.htm Quote Link to comment Share on other sites More sharing options...
