dooroy Posted September 21, 2010 Share Posted September 21, 2010 Removed the front prop from my 2001 Td5 tonight - the middle joint of the double cardan is very notchy ( the one between the 2 universal joints) . Disco wouldn't move then - remembered reading that earlier D2's had difflock but it was not connected. Had a good look and found the 'selector' . Moved it in to difflock ( front flange locked ) and Disco drove OK - but a few lights on . I presume driving like this will cause no further damage - apart from a few lights on ? Any advice welcome . Quote Link to comment Share on other sites More sharing options...
crispyme Posted September 21, 2010 Share Posted September 21, 2010 As long as the front Axle isn't connected you can drive around in Centre diff. lock You may find it a bit 'bangy' when you pull away or take up drive, this is due to the backlash in the locking ring in the T'box - but it's fine .. It's a "Land Rover thing" But you're fine to drive around in rear axle / centre diff lock Eeyore Quote Link to comment Share on other sites More sharing options...
dooroy Posted September 22, 2010 Author Share Posted September 22, 2010 Thanks for reply . And you're right about the 'banging' - the Disco feels very different with only one propshaft . Quote Link to comment Share on other sites More sharing options...
