pete300tdi90 Posted September 23, 2010 Share Posted September 23, 2010 Hey, in my Td5 90, I finally got round to attaching the snorkel to the engine with some flexi hose today and then covered over the end to see if it was water tight.... and engine didnt stall, but then it wouldnt rev up until I opened the end up again. (is this ok for a start, or does it need to stall then engine?) after playing for a while I noticed slight smoke in the cab. the ECU is in the cubby box, but i couldnt deside if it was coming from that, battery box or elsewhere, but it ONLY smokes in the cab when you cover the air intake up. other wise its fine. what the hell is going on?!?!?! Thanks, Pete Quote Link to comment Share on other sites More sharing options...
Ben_J85JTY Posted September 23, 2010 Share Posted September 23, 2010 I am fairly certain that the snorkel shouldn't be able to stall the engine unless you go to real extremes like sealing your airbox. As for the smoke, what did it smell like? My guess would be exhaut gasses. If the joint under the seat isn't sealed correctly, when the truck is stationary those gasses would come up through the floor. Its something you wouldn't notice unless you were stood still. Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 23, 2010 Share Posted September 23, 2010 Is there not a air mass flow sensor? Being TD5 it can probably recognise that there is lack of air flow, so it stope you being able to rev the engine so you don;t damahe something...? just a guess. Smoke being... white? can you see it? smell it, feel it? Quote Link to comment Share on other sites More sharing options...
pete300tdi90 Posted September 23, 2010 Author Share Posted September 23, 2010 i did wonder if there was a sensor... clear/white smoke, only a small amount, didnt smell of anything really... its really strange. i thought about exhaust, but it doesnt smell (which also counts out electrical fault in the bttery bay with all the light/winch wires) any more ideas? Quote Link to comment Share on other sites More sharing options...
