farmer_ben Posted September 23, 2010 Share Posted September 23, 2010 hi, i got bulkhead repair pannels for my 110 i took hinge bolts out but the nuts have fell off the back how do i get to them??????? any help would be great. Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 23, 2010 Share Posted September 23, 2010 hmmm I repeatedly dropped them while I was re-attaching my door, what I did was fished it out using a bit of bent copper wire, from the lower hinge holes in the side, failing that leave it there and buy some more! Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted September 23, 2010 Author Share Posted September 23, 2010 thanks , how do I get to put the nut there?? Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 24, 2010 Share Posted September 24, 2010 Ahhh, you broken the clip fitting then. The nuts are a captive type, held in place by a steel cage/clip fitting that slides into the door pillar hole. Sometimes the clips crack and the square bolt jumps out, in this case you need to get some new fittings. There are heeps of kits on fleebay... My link The part number for the clips is MRC2178 My link Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted September 24, 2010 Author Share Posted September 24, 2010 thanks mate I will have to get some ! Quote Link to comment Share on other sites More sharing options...
